Finnster
KillaHurtz
Finnster's Avatar
08.02.2009, 01:32 AM
These are decent. Rod ends can rip off on jumps/ hvy springs or crashes as there are no downtravel limiters on the Revo, and the shock ends take it. Had a problem a few years ago and these took care of it. Bit of a pain to get in tho.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.02.2009, 11:04 AM
In the picture off the link whats the bronze colored washers for ? or are they bump stops ?
Finnster
KillaHurtz
Finnster's Avatar
08.03.2009, 08:57 PM
There are tiny bearings in the shock end and the brass things are bushings to act as spacers to fit in the rocker arms properly. My bearings eventually failed after a couple years, so I used a vice to press some 3mm spacers into the hole, and just ditch the bushings. They were the spacers included w/ the tie rods for the bearing carriers for bumpstop adjustments. I only ever used one setting (the tall hollow ball) and put the spacers to use.
