I'm running 48/20, which is about the limit for my 4S setup I feel. I've given it the speed run torture test on grass, 2 x 3300 packs back to back & everything ran as warm as I like
I went to the track yesterday & noticed the MMM glitch at startup...it chirped but had no steer or throttle for about 15 secs. It came good & I was nannaing it around for a while, then mid jump (a small one) I lost throttle & rolled forward for a heavy thump on it's lid
Closer inspection showed a fet loose inside the MMM, it was easy to see because the MMM was in half! despite cable ties
Not sure if Castle will look at as a replacement but I'm thinking of an RX8. I may be forced to use my MM until resolved
Yeah that rx8 motor looks sweet Did you have to grind down the chassis to run that 48 thooth? I ask because i just picked up the robinson gear and it hits the bottom.
I didn't need to but I'm using the Losi spur & I'm not sure if the RR is larger (I don't see how it could be?), which kit are you running?
