Gustav
Gustav's Avatar
01.13.2006, 11:54 AM
Do you use a UBEC and have you moved it at all?I've found that moving it just a few mm can make the difference between undriveable interference and no interference at all.Just a thought.
They say the UBEC doesn't create noise,but if it doen't then it sure is affected by it.needs to be kept away from esc and other electrics and facing away.
Edit: do you have another set of betteries to try?
