Andrew32
08.05.2009, 12:59 AM
Originally Posted by blueb8llz View Post
what about when you go in reverse? does it go just as slow or is in normal speed?
im also curious about this, if you have a loose slipper, does this only affect forward motion?
a lose slipper will basically prevent the motor from fully engaging max torque. So it will have the same affect in both forward and reverse.
