Deans are rated for 60A to maintain their specs but everyone runs them above that. Above 60A they're lossier and will heat up but work ok. 4mm bullet connectors are rated between 50-75A. I'd say closer to 50 is more accurate. If you absolutely need max performance bigbullets are the way to go but deans are much easier, dummyproof, and common.
If you need soldering help PM me. I'm IPC certified.
