Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
Ryu James
Ryu James's Avatar
08.06.2009, 08:18 PM
what gears did you order? what are you doing for a spur gear? you doing the same thing i did? did you order that 12t pinion from sdp?
Jammin SCRT10 Neu 1512 1y
KaztheMinotaur
KaztheMinotaur's Avatar
08.06.2009, 08:59 PM
Yeah, I got 40/12 from sdp-si
Ryu James
Ryu James's Avatar
08.07.2009, 01:29 AM
right on. mine are supposed to be here tomorrow and the CNC said if i bring in the 40t he could get it done tomorrow also. be sure to post some pics of your build as you start putting things together.
Ryu James
Ryu James's Avatar
08.07.2009, 09:32 PM
so i got my 40t spur and 12t pinion gear today from sdp. the 40t spur works perfect when you flip the center diff mounts upside down. however, the 12t pinion said that it came with a set-screw in the listing on the site but it showed up today with no set screw. so i am a little chafed about that. it is a really long pinion. i really like it. i am just gonna have my CNC drill and tap it in 2 spots so it will be just like a Tekno long shank pinion. i think it will work well.
and i am still not 100% convinced that these gears need to be hardened. let me know what you think, kaz, when you get yours. they just seem like they are so strong but i dont know a lot about gears and such.
KaztheMinotaur
08.07.2009, 09:37 PM
I just checked my invoice and I deffinately ordered the gear with hub & set screw. This is the part number that I got: A 1C 8MYK15012
Ryu James
Ryu James's Avatar
08.08.2009, 03:40 AM
that is the same part number as mine but it came without a set screw or hole for one. i am gonna call sdp on monday and see if they will send me a new one with the set screw. you'll have to let me know if yours has the set screw when it arrives.
copy from invoice: A 1C 8MYK15012 1 $19.44/EA $19.44
KaztheMinotaur
08.08.2009, 06:17 AM
The gears are scheduled to be delivered on Tuesday so I will let you know. If these gears aren't hardened you could always just drill and tap a set screw hole yourself. Sears sells individual drill and tap sets that range from $4 to $7. Are you goung to grind a flat on the motor shaft for the set screw to hold onto? Are you going to put 2 set screws in the pinion?
I ordered (3) 30mm by 30mm peltier coolers for cooling. They will work great for the ESC but a fan will probably be easier for the motor, because of the round shape.
I ordered some of those Jim Williams strap mounts for the motor. He is about 3 weeks behind making mounts though.
Do you think it would add too much weight to go 10S2P on the batteries?
