08.07.2009, 10:48 AM
BrianG, or any electronic wizard, or anyone who knows what kind of capacitor I need, can I use Mike's from RCM's store?
These?
http://www.rc-monster.com/brushlesscontrollers.php?pg=4
Or could I go with the 2700uF and get better ratings, or could I go higher uF's, and get lower temps, I'm so lost right now..
It is better to use several smaller uF caps in parallel, rather than one large cap- better heat dissipation and responce time to voltage spikes.
That said, a total uF value of about ~5000 shouldnt be exceded, lest you poop yourself at the giant sparks that also eat away at your battery & esc plugs...
Solder them in parallel to the esc's battery wires, + leg of the cap to + wire, and - to -, close to the esc as possible (strip some insulation away with an exacto blade etc).
