Originally Posted by brushlessboy16
BL buggy boy is correct
the entires 15 series will bolt up to the stock mount, your going to need the front spacer plate to clear the mech brakes thought...
THe higher voltage setup will stay cool under higher load (Ie higher gearing) and allow for more speed without heating.
You had better post video. and hope that your good at glueing tires
thanks....but those losi rally tires in my avatar pic are good for atleast 103mph....and i'm knocking on 95 right now. i will post video for sure if i can get a 1521 or 27.
i do have a video of some recent speed runs in the buggy section take a peek if you're inclined to do so
what are you talking about the front spacer plate clearing the mechanical brakes? i don't understand. maybe a few too many cold ones on my part?
can you further explain?
