Its come! A world champion winning buggy with a twist...
jnev
jnev's Avatar
Its come! A world champion winning buggy with a twist... - 08.11.2009, 11:41 PM
http://www.hotbodiesonline.com/kits/en/67535/
I just hope the molded chassis holds up, but I am sure its gone through its paces during testing. Thoughts?
brushlessboy16
brushlessboy16's Avatar
08.11.2009, 11:53 PM
I like the looks of it. but i wonder how the balance is.
and they have a 2200kv motor in a buggy- gotta love the overkill.
Mech brakes is an interesting feature. anyone plan on getting one?
bdebde
That's All Folks!
bdebde's Avatar
08.12.2009, 12:00 AM
I LIKE it. I think that will be my next rig! My old buggy has been discontinued and parts are getting harder to find.
nitrostarter
nitrostarter's Avatar
08.12.2009, 12:06 AM
2200kv in a buggy is perfect. I much rather that than the 2650. It ran so much cooler and seemed to have twice the power.
I love the look of this one. That body is sitting LOOWWWWW on the chassis. I'm not sure if I like the battery and motor on the same side. Seems off balance. Stock with Mechanical Brakes, im iffy on that as well. But this thing looks killer!!
N. Rustler conversion
08.12.2009, 12:18 AM
Meh, I'm not feeling it. Sure, it sits low, but I don't like:
- Motor and battery on one side. Might be hard to balance that.
- Pinion is wayyy too close to the battery for my liking. A good lawn dart and your lipos will be pinion fodder.
- Spiral cut diffs. Puts too much thrust pressure on the bearings. Probably quieter, but who cares really.
- Molded chassis. I'll take the extra weight and durability of a good aluminum chassis anyday.
08.12.2009, 12:42 AM
I like it, kind of.
Things I don't like:
Motor/battery on 1 side
Extra weight and rotating mass of mech brakes
Plastic chassis
Need long wires for motor-ESC and battery-ESC
MetalMan
MetalMan's Avatar
08.12.2009, 01:32 AM
The balance issue actually might not be such a big problem if they could use a smaller spur, which would allow the motor to sit closer to the centerline. It's already got truggy diffs, there's no need for a 50t spur! Heck my Jammin CRT has those spiral cut diffs with a 46t spur, same motor (2200), 5s Lipo, and a 13t pinion. In that buggy on 4s you might need to gear it with an 18t+ pinion which would really push the motor out.
Keep in mind that balance isn't just weight related, but is a combination of weight and the distance from the centerline. If they shifted the CD more toward the right of the buggy and used a 46t spur they could get the motor pretty close to the centerline, probably close enough to negate the battery being on the same side.
I wonder if the 50t spur was included because they intend to have the owner use mechanical brakes? Otherwise that 50t spur option is simply retarded IMO.
OZ-RUSTLER
OZ-RUSTLER's Avatar
08.12.2009, 03:17 AM
IMO they should have designed it to accommodate twin lipo packs.
Foxracin
08.12.2009, 09:16 AM
It will. Just stack them on top of each other.
doo540
08.12.2009, 12:01 PM
When is the truggy version coming out.
lucias
lucias's Avatar
08.12.2009, 12:07 PM
My work filters this site... "hotbodies" is a "sex" site... lol
sabongi
08.12.2009, 02:38 PM
140mm max battery length, same side of motor and close to the pinion? I don't like it...
Zippys won't fit!!
emaxxnitro
emaxxnitro's Avatar
08.12.2009, 02:49 PM
i will get it. if its around $300
808E
nitrostarter
08.12.2009, 02:53 PM
I dont think it will be that cheap. I'm thinking around $400...
bdebde
That's All Folks!
bdebde's Avatar
08.12.2009, 03:11 PM
Nitro version is about $300, don't see why this wouldn't be about the same.
