08.12.2009, 08:55 PM
ok, now i am looking for different tires for the hyper ste. i plan on using standard 2.2 tires since the ste uses a 12mm hex. the stock tires are too small IMHO and they will wear out fast on pavement. i drive on pavement about 75% of the time and i am looking for the longest lasting tire possible. i don't mind giving up a little traction to do so either as i usually run bald talons on my rustler and i like drifting on-power around the turns.
so, ideally, i want a 4"-4.4" tire that will last as long as possible on pavement. i don't care if the tire has no grip in dirt or grass as that is what the stock tires will be for. i was looking at the dirt hawgs, but i've seen them wear out on a weak nitro x-cellerator. so, the main goal is longevity on pavement.
edit: also, i am trying to figure out which pinion gears i'll need by using the speed calculator and i want to know the stock tire size, the stock spur gear size and the diff ratio.
would a 20c 3000mah lipo be sufficient for running a KD 36-60 3000kv motor, or should i get a 30c 3000-3300mah lipo?
thanks for all the help
