lutach
lutach's Avatar
08.13.2009, 02:03 PM
Originally Posted by drkdgglr View Post
Wouldn't you only benefit from this extra torque in a low kv & high voltage setup vs a high kv and low voltage setup?
Although the 1400kv motor would have more torque than a 1700kv, you'd have to gear the 1400kv motor higher to reach the same speed as the 1700kv motor.
I entered two buggy setups in the speedalc. Only difference between the two is gearing and motor. I used a 1515 3d (1360kv) and 1515 2.d (1650kv). According to the calc the 1360 kv has more motor torque, but the final torque is exactly the same as the 1650kv setup. I am assumng that both setups would have the same amp draw (this is were I could be going wrong)
1515 3d:
Total Motor Speed: 28886.4 RPM
Vehicle Speed: 34.83 mph (55.94 km/h)
Effective KV Value: 1301.19
KT constant: 0.99 oz-in/A
Motor Torque: 0.41 ft-lbs
Final Torque: 4.6 ft-lbs
Final Power: 1776 watts (2.4 HP)
1515 2.5d
Total Motor Speed: 35310 RPM
Vehicle Speed: 34.93 mph (56.12 km/h)
Effective KV Value: 1590.54
KT constant: 0.82 oz-in/A
Motor Torque: 0.34 ft-lbs
Final Torque: 4.62 ft-lbs
Another thing I was thinking is that you'll be running the 1360kv motor closer to it's max rated amps and will run hot easier?
From what I've seen in my set ups, all the higher Kv motors geared for the same speed have always asked for more AMPs then with a lower Kv ones. It might have to do with the winding resistance (Rt) and the fact that most higher Kv motor have higher Io (No Load Current). For example: A Aveox 1415/2Y has a Rt of 0.022 Ohms and a Io of 1.8, now a 1415/1.5Y has a Rt of 0.010 Ohms and a Io of 2.5. I have tried the 2 motors above with 6S both geared for the same speed and the 1.5Y was always warmer and pulled more AMPs then the 2Y.
