I need a battery for my losi 8t 2.0 truggy.I check out the hyperion site
and found a heperion lvz 4s 30c 5000mah 14.8 v at 135 continous amps.
Will this work ,this is my set up.MMM combo 2200 kv.I know the combo
is rated for 120 amps,will this battery be to much for my setup?
Yes Dirtdiver, get the G3 packs, I have a 6s 4200mah 35C pack and it knocks the $#!t out of your @$$.
Get the 6500mah pack, IMO, should provide you with 20+ mins of hard bashing or racing. You won't believe the power from these things, your 8T will come alive. GUARANTEED!
I know the higher the amps the cooler the battery will be,but the higher the amps,
the higher the price.Trying to save a little money for other things, but can i get away
with a 5000 mah 30c battery,and still run a cool setup?
The VZ Hyperion is the old gen packs, which you can get for some steal deals from aircraft-world.com on the 'clearance' items. Definitely good packs, but in the long run, you are better off getting the G3 35C packs, actually underrated relatively compared to the 'old' C ratings, they can be charged 5C (have done so myself), and they claim that the G3's last 4x longer (cycle life).
But if you want to spend a little less get the VZ 4500mah 5s pack, and gear it lower than you would with 4s, will run great! They are $114 right now!
