Originally posted by coolhandcountry
I got a question. I like to know how an esc works. Does it regulate the amount of volts or the amount of amps?
It regulates output voltage by PWM (pulse width modulation) and this automatically regulates current as well.
There are modes when ESC can regulate current, to maintain constant RPM.
Brushed (Digital) or Brushless ESC works similar (brushed has one phase, brushless 3 phases).
Switching frequency selection based on motor inductance. Higher turn motor has higher inductance. Higher frequency allows getting more steps in regulating output voltage and makes motor to run smoother. But running at higher frequency taxes ESC efficiency, more times switching occur more power loss on FET. Details can be provided later.
To run ESC in the most efficient way you should select highest frequency for low turn motor and the lowest one for high turn.
For a example 7XL – 9 kHz and 8S – 19 kHz (or even 38 kHz) Schulze example.
Testing will tell you which one is the best but do not set 38 kHz for 7XL. When changing frequency only ESC temperature should be affected because frequency over 1-2kHz doesn't effect motor to much if at all. You can run low turn motor on low frequency but then it should be less smooth.
If you do not know what motor you have and what settings to use, start from low frequency and step up until your ESC start radiating significant amount of heat and then step back.
BEC is a simple voltage regulator. Most ESC produces 5-6V and can deliver 1-5A based on particular model. Key factor here is power dissipation. If it is not build based on DC-DC switcher then most TO-220, D2-PAK rated to 1-3W (without heatsink or extra cooling) and if BEC generated from 7.2V then you can easily draw 1A without overtaxing BEC regulator (7.2-5*1=2.2W). But if you start from 14.4V and 1A you do the math…
Most Voltage regulators have built-in over-temp protection which reduces output voltage to limit output power. Extra cooling helps but not much.
Ultimate BEC (with DC-DC converter) is the only one solution.
That is why if you increase BEC voltage output it is better from both sides, better for us (more power to servos) and better for regulating part less heat dissipation. But it is hard to maintain 6V (for BEC) if you run from 7.2V, not enough voltage for reliable regulation, not mentioning voltage drop upon battery use.
Artur
P.S.
Some links from my BLDC web collection
http://www.torcman.de/peterslrk/SPEE...l#Anker1591256
http://www.servomag.com/flash/2-pole...ldc-motor.html
