Also, first time I did connect the esc, I had to wait a while, like a minute or two before it connected. IDK if it has to finish installing, or takes a while to find first time or what. Set it all up and let it sit for a bit. The comp should make a "usb device connected" sound as soon as you plug in the usbcom.
Also, make sure the SW is setup to see the USB port and not a COM port.
