whitrzac
Can't catch this...
whitrzac's Avatar
08.17.2009, 03:11 PM
Originally Posted by KaztheMinotaur View Post
I'll try to get some pics but it seems real crowded in there.
How else can I boost the voltage?
idk how, but...
http://www.hobbycity.com/hobbycity/s...Chargers_(350W)
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.17.2009, 03:51 PM
Yes, there could be pots in there that can be adjusted to a certain degree, maybe .5 - 1.0 volts +/-.
If it's a decent power supply, they can always hold at least 11.8 volts a heavy load, some PSU's are so so stable that they don't even flinch under the most extreme loads.
Post a link to the model you purchased.
KaztheMinotaur
KaztheMinotaur's Avatar
08.17.2009, 04:05 PM
http://www.chiefmax.com/psu/cm650-24pin.php
zeropointbug
Z-Pinch racer
08.17.2009, 07:11 PM
Well 650watts should do it, but alot (alot) of the cheapo computer PSU's have a hard time keeping up with any kind of load.
How much did you pay for it shipped?
KaztheMinotaur
08.17.2009, 08:19 PM
$25
I was practicing on my old power supply and got the up to 12.46 with 2 1 ohm resistors paralled on the 5V line. It drops about a volt under load though.
KaztheMinotaur
08.20.2009, 12:13 AM
Here is another thought: What about connecting the 12V and 5V from 2 different power supplies together in series to get 17V? The ground to the 110wall socket, on 1 PS, would have to be disabled right?
In this situation since I would be using the 5V rail can I put the load on the
3V rail and have the same effect?
zeropointbug
Z-Pinch racer
08.20.2009, 12:48 AM
If you want to get two power supplies, why wouldn't you just get a 12v lead acid battery. I went from using a 250watt chargery psu to a 12v batt actively being charged at the same time, and has been trouble free ever since. The power supply used to dip in voltage to much, or hiccup, or some other power instability issue, causing the Hyperion charger to reset.
Then you can even charge batteries a few times while out in the boonies where there is no power... it's nice to have. You could even find a second hand starter battery that would do the job for cheap.
