candy76man
08.20.2009, 05:33 PM
Originally Posted by adrictan View Post
Can I check if I use this:
http://www.swanghobby.com/flyermate-...1-pr-1679.html
What charge rate should I set on the charger? I use 2s 5000mAh lipos. Can I set it on 4s and charge at 5A? would charging time be lengthened by charging 2 lipos together?
It should work.
Your charge rate settings depends on what you're charging though. To charge two 3s 5000 mah packs at once for instance, you would set the charger to 6s and 5 amp charge rate...it shouldn't take much longer than charging a single pack.
