If its mounted like i think it is (screwed to the mounting holes of second motor mount) then its a perfectly fine idea many people mount there controllers that way
Originally posted by stampy If its mounted like i think it is (screwed to the mounting holes of second motor mount) then its a perfectly fine idea many people mount there controllers that way
Yep, that is what it is. Being new to RC, I haven't seen it done.
be careful with those rpm arms and the cvds. i have heard of people getting in a bad crash and the arms bending like there supposed to but when they bent the cvd came out and did some damage.
Originally posted by Sneeck Yeah, i'd make it so it still mount's there, but let's the esc sit lower. Also be sure to have enough padding on the back of the esc.
Originally posted by squeeforever be careful with those rpm arms and the cvds. i have heard of people getting in a bad crash and the arms bending like there supposed to but when they bent the cvd came out and did some damage.
Thanks for the tip. I will try to remember that when I get things runnin again.
i've bend 2 ue cvd's by running rpm arm's. They bend due to tight cornering at full speed(permax 600's motor's) no crash or jumping involded. pb depth was normal.
