Originally Posted by Freakycrawler
that noise are you diffs that are slipping because off wear, had the same problem and heard it to with hard acceleration .
Gotta relace your diffs and shim them right
thanks for the heads up mate ,will have to look into it again ,didn't look worn the last time I checked
hey what weight oil should I use in the centre ???? want to try and stop the front wheels balloning so much..................
