08.30.2009, 01:58 AM
If you want to do it, do it! It will work and will be awesome! I'd love to see it!
However- If your goal is top speed a single setup is better. Every gram counts in top speed runs, the additional weight would be substantial.
Also, high voltage is the way to put down power. 12s at 100 amps is 4400 watts, or 5.91 hp. To make that power on 6s takes 200 amps, which equals alot more heat and possibly fried components.
I know you plan to "split the load", but you'll be pushing things.
I say do it and see what happens. Do it your own way! (post video please!)
