Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
drkdgglr
08.31.2009, 09:40 AM
After that I swapped the gears in the tranny to get a slighly higher ratio. Simple mod, requires slight clearancing on the inside of the trans case. Completely reversible too. Basically threre are 2 gears in the tranny, a 22t and a 23t, I swaped them to help out my slower turning motor (1500kv on 6s) get to 40mph with my available gearing choices.
you can now also use the lst xxl output gears to get almost the same reduction as the swap mod (swap mod 1,89 / xxl gears 1,91). the output gears in the xxl are 29/16 (losb3119). the output gears in the lst2 are 30/15.
you can also do both: swap mod&xxl output gears (1,73 reduction)
