emaxxnitro
emaxxnitro's Avatar
08.31.2009, 11:29 AM
Originally Posted by Rivermaxx View Post
Neil we are talking about mod1 gears not .8 or 32p gears. A 25 tooth mod 1 is bigger than a 27 tooth .8 or 32p. Bigger than 25 tooth mod 1 steel gear is almost non existant.
a 25t mod 1 gear is huge .
ok i got 4 ofna blue dot foams, losi eight e 43t spur plastic ( lighter than metal )
hpi 25t pinion gear, 6s 30c turnigy lipo, high down force wing. mamba monster 2650.
seem like a setup?
808E
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
08.31.2009, 02:24 PM
seem like a setup?
i did 100+ this morning with 30C flightmaxx lipos, 34/25(mike's mod 1 is lighter than HPI, i have both) with green springs all around(you need it to be soft and low) with the 2650. on the mamba settings, 0% punch control, no reverse and everything else stock except i did use the hi-flow ofna wing...that made a big difference in control ability....after 5 passes the 2650 was 128 degrees, the esc was 90 and the batteries 91.
i was also using the losi rally tires. i think if anything stops you from getting 100 it would be wheel spin on the foams.
also, make sure your drive train isn't binding in any way and is very free spinning. that's why you'll need to sand like 1/8" of the face of the 43T to prevent binding the center diff and the motor mount.
i love this setup...i just bought another 2650 MMM combo an hour ago so i could build another. thanks to OverrevO for the suggestions. bye bye to my 1.5D. it had too much torque for me.
I'll get video of it on my day off saturday.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
