kazuaki
08.31.2009, 01:05 PM
So, how would this work out?
  • Neu 1512/2D (2550kv)
  • Mamba Max Pro
  • 2 - Hyperion G3 VX packs in series (3S 1600mah 35C/65C)
08.31.2009, 01:30 PM
  • Mamba Max Pro
It should fly
kazuaki
08.31.2009, 01:37 PM
And this should be faster than a 1512/1D (4875kv) on the same packs in parallel? This wouold make the battery setup 3S 3200mah 35C/65C, which should have twice the current capability right?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.31.2009, 02:31 PM
Yes, the 2D would be faster and run cooler, go for the 2D over the 1D.
You know what, I am running a 1512/3D in my Revo and it can crank out 2200+watts, was the most I have caught on Eagletree, probably has been higher even.
A 2D on 6s in a 1/16.... that will be... I don't know, something else.
You will definitely be pushing those packs to the limit, they can probably deliver 1800watts peak, and ~1100watts continuous. You might want to get a larger pack to handle the power that the 1512 can turn out. You should maybe consider getting the 2200's or 2600's, that should get you a sizable speed increase alone, even with the 1112 you are using now.
kazuaki
08.31.2009, 02:58 PM
Oh, no question larger packs would be better. The problem is, they won't fit in the 1/16 compartments. The 3S 1600 appears to be the largest that will fit.
kazuaki
08.31.2009, 06:15 PM
So, help me understand this
I just threw the stock 1/16 VXL motor back into the truck to see what it would do. I dropped the gearing to 39/45 since this motor is rated for 4000kv and should turn more RPM. I was able to get the same 73 MPH with the same ESC and batteries as the Neu 1112. How is that possible? The motor ran a bunch hotter than the Neu, but how can the Neu not be any more powerful than the stock 1/16 VXL motor? Does this point to the EZRUN 60A ESC or something else as being my limiting factor maybe?
