BL_Revo_Inferno
08.31.2009, 05:44 PM
Since this is a Inferno GT Post I thought I'd ask here I have a Brushless Inferno GT (Subie STI) that has a 777 Center Diff 46 tooth spur 300k silicone in it and 18 tooth Pinion CC Mamba Monster Max and CC/Neu 2200kv motor rest of drivetrain is stock the car is a tank I have not broken it yet I am running 5000mah 25c 5s battery My Problem is I am annhilating tires I have tried on road hard tires and they last 2-3 runs tried some heavy offroad tires and they lasted a little longer but they blew up too tried some pro line crimefighter again just to see and they didn't last very long at all I asked at my Hobby Shop about the Ofna belted tires and they said they were not very good so I have been looking at doing a conversion to fit 1/5th scale touring car tires to it and see if they last any better. Just for info on how I mount the tires I glue them them both on the inside and outside. this is my speed car straight down the road high speed runs try to avoid donuts as this ruins the tires faster. Any insight would be Greatly appreciated I am going tomorrow to see how much work and money is needed to do the 1/5 scale tires want to avoid this as they are wider and will look weird on the car. Thanks
streethot
08.31.2009, 05:53 PM
The best and only tire I will ever use on a IGT is OFNA belted tires, BELTED,
its a little more expensive but there is grip enough to glue the IGT over 60-70mph.....IMO......
Originally Posted by BL_Revo_Inferno View Post
Since this is a Inferno GT Post I thought I'd ask here I have a Brushless Inferno GT (Subie STI) that has a 777 Center Diff 54 tooth spur 300k silicone in it and 18 tooth Pinion CC Mamba Monster Max and CC/Neu 2200kv motor rest of drivetrain is stock the car is a tank I have not broken it yet I am running 5000mah 25c 5s battery My Problem is I am annhilating tires I have tried on road hard tires and they last 2-3 runs tried some heavy offroad tires and they lasted a little longer but they blew up too tried some pro line crimefighter again just to see and they didn't last very long at all I asked at my Hobby Shop about the Ofna belted tires and they said they were not very good so I have been looking at doing a conversion to fit 1/5th scale touring car tires to it and see if they last any better. Just for info on how I mount the tires I glue them them both on the inside and outside. this is my speed car straight down the road high speed runs try to avoid donuts as this ruins the tires faster. Any insight would be Greatly appreciated I am going tomorrow to see how much work and money is needed to do the 1/5 scale tires want to avoid this as they are wider and will look weird on the car. Thanks
RC8 MMM 2200kv 4s
Serpent 960 MMM 2650kv 4s
Serpent 835 MM Neu 1509 4s
