08.31.2009, 11:26 PM
Hook up your pack main leads, then balance leads to the LBA. At this point the mode light should be on solid, and the cell LEDs may blink depending if they need balancing or not. Hook the LBA to the charger. Then press the mode buttonl the mode light should now blink slowly.
Brian! You rule! It works perfectly now!
