R00ST
09.01.2009, 11:41 PM
Pretty sure Justpassedu you has the mini STE which would explain the cvd color. The truck does look similar to the .5 with the body on though.
And as far as what to run for shims...I used shims lol. If you have a local RC shop go look at their shim's (not even sure what material most of them are... almost like a teflon/delron flexible plastic material). Usually they come in all different thicknesses and diameters. I just have a TON of rc stuff laying around so I dug though my box o junk and found some that worked.
That...or if you have an O-ring kit or know someone who does. If you can find an o-ring that is small enough to go around the axle and the thickness is not too thick you can run that.
