scarletboa
scarletboa's Avatar
09.04.2009, 09:08 PM
those chargers have a 3 month or 1 yr warranty. i have the $35 version and it has worked very well for me. the only downside of getting a warranty replacement is sending the defective one in. shipping to hong kong is a little pricey.
that charger is supposed to have the same "brains" as mine and mine is dead accurate. 4.20 is the usual cutoff per cell. occasionally it'll only go to 4.19, but that is good enough unless you have severe OCD.
edit: i have that 2x3s adaptor, but only because i run 2 3s packs in my BL converted savage. if you do end up ordering from hc again, you should pick up 2 of these
http://www.hobbycity.com/hobbycity/s..._20C_Lipo_Pack
those packs are only 20c, so if i were you, i would use the 18t pinion for 6s. some people say those packs are underrated and are actually 25c packs. for $30 each, you can't go wrong.
