Originally posted by mmdooley
Gustav: I am worried about the play in the cvd's. They were like that when I got the truck. Does anyone else have that much play in there cvd's?
Maybe they're not even for a maxx,just a thought.I've never known that much play before,that's why i mentioned if the emaxx uses a spacer between the bearings or not. i don't think it does though but not sure.Where did the bearings come from,maybe they're 4mm wide and should be 5mm.Is the drive pin all the way into the hex?if not then tightening the wheel on would remove some of the play i guess.don't really know what else to suggest.
