J57ltr
09.07.2009, 02:34 PM
I didn't think that red would hold that's not its purpose. The green sleeve retaining compound will hold. It's still holding up on my motor. They also recommend using the primer before using most of their products. I haven't used it before except when I worked for Western Atlas where it was part of the procedure.
Using Loctite is just like anything else it has to be used properly if the surfaces are not completely clean and free anything but the substrate you are attaching it won't bond. If there is any oil at all it won’t set. Anodizing needs to be removed and both surfaces roughed up for it to work, same with JB weld although I have yet to find anything that it is good for. At least it never works where I need it to.
Jeff
