Originally Posted by superek4
So it does not make sense if the 6-8 pole motor is 70/80mm? The amp draw will be higher too right?
Brian what do mean by" Another consideration is that the more poles a motor has, the more the ESC has to commutate and may hit a rpm limit"
u meant the esc can't handle the rmp or amp draw?
The brushless esc manual will often state a max rpm for 2/4/6/8 pole motor
The max rpm for a 2 pole will be higher than a 4 pole and so on....
So an eight pole may be limited to a small max rpm value depending on the esc.
