09.09.2009, 09:56 AM
The shaft supplied with the FLM chassis will work with the stock 3905 tranny, its pusrpose made to fit correctly. The FLM shafts *should* come with cups to fit the tranny, so you wont need to buy any (will be easy to find some if you need them so no worries).
As far as setups go, that looks fine. Not sure on the shock diameter, so be prepared to trim your a-arms if needed (this subject has be discussed in enough detail I believe).
I think all you're missing are the steering parts- bellcranks, turnbuckles and knuckles- I would use stock 3905 or tmaxx3.3 parts from ebay, they will be a direct fit and are pretty durable I have found.
