Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Rivermaxx
09.12.2009, 06:11 AM
Thanks harold for the offer but I did a lot of research and searching for just the right parts and have got the gear ratio figured out. My stuff is not nescessarly better but maybe a little lighter youll be surprised when you see the pics. Biggest issue was the size of the tires killling my final ratio. That why I needed to not run buggy size tires. I also didnt want skeptics saying my truck is no longer a monster truck with the small tires. My actual final speed is alot higher with my set up than yours with a 2200kv motor. When putting in those numbers you need to use 3.00 volts per cell also. I picked up a real Neu 1515 1.5d 2700 kv motor which helps also. I am also running a 40 tooth spur and 30 tooth pinion. My truck now is ~7#s without electronics body and wheels and tires I am pushing for sub 9#'s complete. Most mt's are in the 11- 12 #s complete.
