crjackson
03.12.2005, 07:12 PM
Originally posted by RC-Monster Mike
What other radio system did you try? Did you also program the controller before you tried to use it? I don’t blame you for wanting to burn the thing up, but it must be something we are missing. Also, I don’t quite understand the motor knock you described. Is it a rough spot in the bearing or does it seem like something else?
Mike, I answered by email. For the benifit of others reading, I'll reply here as well.
Traxxas stock radio system
Yes, I programed the controller many times
The knock is internal. It sounds like something on the armature is expanding when the rpms increase, and then knocking against the winding cores. It happens with the motor out of the truck and being held in your hand. I knocks so hard, you must hang on tight or it will jump out of your hand.
It does not feel like a bearing. The rotation of the armature is smooth when turned by hand, and at low rpms.
Also the motor has no power. It's very weak.
