Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.14.2009, 08:14 PM
Now I had to cut the sheet to size that I needed, I made it a little bit bigger because you can always cut some off later... Made the mounting holes for the 3080 motor, and made sure everything was centered...
Now I had to make cut down the original sleeves to bolt the aluminum motor mount onto the stock Motor Mount...
The hard part is pretty much done.. All I have to do now is mount the motor and wait for the sleeve to come in... I had to cut the original clutch bell, because the sleeve/collet will all attach the 10mm LMT 3080 Shaft to the cut shaft from the bell shaft... Hard for me to explain.. here's what I did..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
