09.15.2009, 12:10 AM
Thanks Neil, you were actually dead on. I had it on brake then reverse but after trying the proportional with lock-out it works much better. With some fine tuning I will be able to find the sweet spot.
It does make that weird sound on braking like I have heard on some brushless systems....like pulling and releasing a sprung door stop. I dunno if this is norm with the MMM as this is the first of my encounter. Just running higher voltage makes me a bit more leary on strange sounds.
Other then this all is much better. Now if I can only keep the tires on the rim.
