09.16.2009, 06:28 AM
nope, not the motor, poor setup
I'd check caster, camber and toe ins on all 4 corners. holding a ruler flat to the face of the tire gives you a good visual to approximate degrees.
A decent spot to start is 1 degree camber on all 4 tires (tops point in to chassis)
1 degree toe out up front and 1 degree toe in out back
and make sure caster is equal on both sides
Dafni
Dafni's Avatar
09.16.2009, 07:54 AM
On a direct-drive setup with a centerdiff the torque-steer gets kinda canceled out by the weight of the diff spinning in the opposite direction.
If you have a large heavy rotor I can imagine you may feel a bit of torque twist/steer, but nothing like you described.
On that note, I once had a setup with an idler between diff and motor (i.e. diff and motor spinning in the same direction) and the torque steer was noticeable on straight-line dragracing, or in mid-air.
I guess your issue is indeed setup related. Check all the settings. A slightly bad bearing somewhere might cause the same issue, btw.
Daf
steveo
09.16.2009, 07:10 PM
thanks i will check al 4 corners, got it from e-bay so you never know what someone else had it dialed in for
