My dual BL set-up
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
My dual BL set-up - 03.11.2005, 04:53 AM
I received my motors and controlers last week and was just waiting for my batteries to come before I tackled this project. Holy Crud there is a lot of wires!:eek: So the batteries came today (pro-match) and they sent me the wrong configuration. I wanted each pack to be 7cells flat (for g-maxx chassis) but they sent me 6cells flat with 7th on top!:mad: So, off they go back to where they came from to hopefuly get the ones that I ordered and get this beast put together. Speaking of which, anybody live in the Orange County/Riverside County area want to come over and help me put this thing together:lol I am going to need your guys' serious help guideing me through this because I have no clue what I am doing:C: I'll let you know when I get the batteries back.
John
MaxxFusion
MaxxFusion's Avatar
03.11.2005, 08:28 AM
NP. The biggest thing is take you time with the wiring and keep it neat. It will pay off in the end. Get a ton of zip ties. lol
  Send a message via MSN to MaxxFusion
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.11.2005, 06:42 PM
I live in Orange County! Too bad it's Orange County New York! :)
Feel free to post pictures and ask as many questions as you want. We will do our best to answer your questions and get you rolling with your insane system. You will need a receiver pack for that set-up for starters (you possibly know this already). The controller will be wired to the receiver in parallel, I assume, so you will need that connector as well.
Chase023
Chase023's Avatar
03.11.2005, 07:25 PM
Ya I live in Orange County CA but Riverside is still a bit far.. heh..
Embrace the Speed!
 Send a message via ICQ to Chase023 Send a message via AIM to Chase023
JOHNNYMAXXIMA
03.12.2005, 02:02 AM
Where in O.C.? I grew up there.
Chase023
Chase023's Avatar
03.12.2005, 02:26 AM
You still need help putting that thing together??
By the way I am between Irvine and Orange.. heh
Embrace the Speed!
JOHNNYMAXXIMA
03.12.2005, 03:19 AM
Ill let you all know if.. I Mean when I need Help. :D
JOHNNYMAXXIMA
03.13.2005, 01:40 AM
OK Mike,
This is all I have in hand right now.
2 motors
2 speed control
1 UBEC
2 20t pinion
and some deans plugs.
What else am I going to need and where should I get it?
Thanks
Serum
Serum's Avatar
03.13.2005, 05:20 AM
What motor/esc combi are you using?
And what diffs/drivetrain hopups are you using?
JOHNNYMAXXIMA
03.13.2005, 06:10 AM
Hello Serum
I have the 9L/9918 combo.
Stock diff up front (for now) and a spool in the rear, although not too sure how that is going to hold up.
I have RDL CVDs at all 4 corners and am currently trying to find any type of center CVDs (other than stock) but I am not having any luck. I found some MIPs on ebay, but they were the black and I prefer the shiny. Might just have to settle though.
I also tryed to get some of those ultramaxx tranny gears that were being offered in another thread here somewhere, but may have been too late because he did not respond to my second e-mail.:( Maybe Mike is still working on something?
Serum
Serum's Avatar
03.13.2005, 06:16 AM
MIP center cvd's only come in black.
You could also use the UE titaniums.
The only weak link in the gearbox are actually the idlers, so you could buy a UE set of these.
I don't know how long your diffs would last.. depends much on your type of driving.
If you need bulletproof diffs, ask Mike for the Fastlane bulkless 1/8th set and the HB diffs.
820maxx
03.13.2005, 10:07 AM
did u try the ultramaxx web site also if u have the truck apart u might want 2 put 3mm screws in the spool i have broke those little ones with drill motors
RC-Monster Mike
Site Owner
03.13.2005, 10:10 AM
The RD Logics cvds don't work with the 1/8 diffs. The Maximizer diff cups with stock spiders and aluminum cases are very stout gears, though (although I can't seem top get the diff cases anywhere). The stockers won't hold up for two long if you drive hard. The spool will shear the 4 small screws that hold it to the ring gear and stock stock plastic diff will flex and fail.
Superemaxx89
03.13.2005, 11:34 PM
you'll need some Y-harness' as well. Get the UE steel CVD's...Cost the same as MIP, yet 10x stronger (really, just look on their site!), better wheel hex design, bragging rights, professionally assembled, much much more...UE steel is stronger than titanium.
JOHNNYMAXXIMA
03.14.2005, 04:26 AM
I guess I'll give UE another chance for the CVDs. Poor customer service really erks me though.
What do you guys think about Traxxas' light weight stuff for the tranny (Lightweight Input Shaft/Drive Gear Assembly and lightweight Output/Idler Gear Shaft) part #s 3993X & 3994X. Any good?
As far as the Y-harness' go, what are they for and where do I get them? Again, I have no clue as to what I am doing, but given instructions, I am pretty mechanicly inclined and will have no problem putting this thing together.:D
Thanks
