Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
jzemaxx
09.17.2009, 05:51 PM
It seems to me the biggest problem at high speeds is the body acting like a parachute and the truck lifting, jze always ran no body. You can seal the edges of the body but the wheelwells will always be taking in huge amounts of air.
My thinking is that the body needs to be as "aerodynamically transparent" as possible. Basically a swiss cheese body. So the air doesn't get "caught' under the body. Once testing begins if you could sacrifice a body to try it could make a difference.
I really think they only lift at speed because of the body, they don't seem to lift bodyless.
Just thinking out loud.......
Actually I did run a body.....That is why it would act like a kite.
http://www.youtube.com/user/RCTVLIVE.../1/E1-XCew1rCk
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
09.17.2009, 06:06 PM
bad linky
.....swiss cheese body........
jzemaxx
09.17.2009, 06:08 PM
Link should work now....
http://www.youtube.com/watch?v=E1-XCew1rCk
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
JThiessen
JThiessen's Avatar
09.17.2009, 06:58 PM
Your probably correct on the body causing lift after a certain speed. The theory of using no body to aleviate lift at those speeds would be spot on, but then you are faced with overcoming the drag. A front wing might be the key for getting the majority of the air to flow over the truck - I'd even consider one that extended beyond the wheels.
