09.19.2009, 10:35 AM
Ok, so I was just on the site and this is not a diff set, but just the ring and pinion....no spider gears.
From the site...
This Machined Bulletproof Diff Bevel Gear Set is our toughest diff set-up ever for the Savage monster truck line. The ring gear and pinion gears are precision machined from high carbon steel and have stronger gear profiles for the ultimate in durability. The 29T gear is machined to use the included "oversized" ball bearing for extra durability and efficiency.
This diff gear set was developed for extremely high horsepower applications like the Savage Flux and Savage XL. It's so strong that it replaces the 86922 and 102246 Heavy Duty and Super Duty gear sets, both now discontinued. So if you're using big block nitro engines or high voltage brushless motors, get the new Machined Bulletproof gear set!
Each package upgrades one diff, we recommend getting a pair of them so you can upgrade the front and rear diffs. Fits all Savage trucks. Recommended for use with 102272 Composite Gear Box/Bulkhead Set
FLM Extended Savage -Nue 1521 2d MMMv3 6cell
E-Maxx -Flm Parts stock motors (the wife's)
Slash -MM medusa 3300k 3cell 68 mph!
[B]Custom FLM Axial Crawler
Losi Rammunition 1/184600k
