Originally Posted by Emaxx_Quebec
When you say to plug a srevo( steering) in the throttle chanel, you mean once mmm is on or before open it.
When I hook up a servo to the throttle channel to see if it is working correctly, it would not even arm. ( normal I think since the MMM is hook to ch1)
No, just run the RX and servos with a battery. Plug an extra servo into the throttle channel to see what the throttle is ACTUALLY doing.
You don't need the MMM hooked up -- just make sure the servo moves as expected, i.e., when you hit throttle the servo moves one direction, and when you hit brake the servo moves the other direction.
