Originally Posted by bigboi146
Hey guys I was out running my hyper st. Here's my problem up until a couple days ago, every time I give my truck a good amount of throttle(100k center diff oil) it makes a very harsh noise as if gears are grinding. I've since disassembled the center and rear diff and found the gears to be in good shape. Am I missing something here?
Originally Posted by _paralyzed_
if any gears are skipping it will be quite evident. keep digging till you find the carnage. i suspect the front diff. people always assume fronts will hold up, but 75% of the braking force is up front and that'll eat diffs
Rear diff gets a good majority of the force under accerleation..
CHeck your teeth on the rear diff ring gear
they are probably rounded slightly causing the gears to skip under load.
ANother possibility is that one of the magnets inside your motor is debonded and is grinding on the inner windings of the motor- had that happen this past weekend
