J57ltr
09.25.2009, 10:51 PM
Both methods will work in plastic just fine. I use a slightly smaller hole and tap the insert in place. When you tighten the screw in place the sides wil spread out and make a tight hold.
What epoxy do you use for bedding? I have always used fiberglass resin.
Jeff
