Gee
A Horse's Ass
Gee's Avatar
09.27.2009, 04:16 AM
Well that sounds good. You can use a different ring gear/pinion in the LST cases as long as they are the standard 1/8th scale size. Selective gearing vs just using what the LST comes with. Although it doesn't look there a bunch of different option out there.
Semi Pro I did some more calculation or should I say played around some more with Brians Calculator. I found that the muggy gear ratio bring the numbers I was putting in real close to the 1:1 Rollout. So I think I am getting what you mean by the muggy diffs being a better fit.
Thanks for the help guys.
