Jabe
09.29.2009, 12:07 PM
I cant deside what motormount to use, obviously 808 wont fit, so which mount to use Tekno or RCM.
Both has up and down side, Tekno needs holes to chassis but centerdiff is easy to remove. RCM is bolt on solution but removing centerdiff is PITA.
All rcm mounts should be designed like 808, its great desing!
Or should i get RCM mount and try to mod it, so that it uses stock upper part?
