Pdelcast
Pdelcast's Avatar
10.01.2009, 11:46 AM
M.M.M. save some more $$. You'll be better of in the long run.
Agreed -- The MM Pro handles 1/10th and 1/8th buggies, but isn't intended for monster trucks. The MMM is a much better choice.
The MM Pro has 18 x 1.2 milliohm FETs (.0004 ohms), and the MMM has 36 x 1.8 milliohm FETs (.0003 ohms.)
So the MMM has lower resistance, a larger fan, a larger heat sink, and a larger circuit board (for heat spreading.) The MMM will handle the current level on your Savage better than the MM Pro.
In our testing, the MM Pro handles about 2/3 the current of the MMM.
Thanx!
Patrick
Patrick del Castillo
President, Principle Engineer
