10.07.2009, 12:39 PM
For the mini e-revo? I'd use a MMPro. Aside from the data logging, it will have pretty much anything you want for that vehicle.
crazyjr
crazyjr's Avatar
10.07.2009, 04:46 PM
I'm looking for a small 6s esc. Even though its not the quark65 in size, the MMpro will still be quite large on the Mini E-revo. I think the ice 50 6s would be perfect for what i plan, If the programming can crossover
10.07.2009, 05:08 PM
Well, the MMPro is very close in size to a MM, if that tells you anything. Most of the height is due to the fan assembly, and if being used in something that small, heat shouldn't be an issue even without the fan. I guess it depends on how soon you plan on getting the ESC; I would imagine the MMPro will be out sooner than the ICE ESC.
crazyjr
crazyjr's Avatar
10.07.2009, 07:07 PM
I understand on the size, and thanks for the size update. I am trying to go as light as possible, due to running two 3s packs. I'm not sure, but i might run my 1200basic xl lehner 540 based motor.In my Gt conversion, it pulls only 40 amp peaks, so no problem running it there on a 50 amp esc
Honestly, I can wait, I do not have the funds now but later this or next year i should be able to set this up. I am looking to make a chassis similar to the Mini E-revo one in the brushless section
