10.09.2009, 02:10 PM
Originally Posted by Cain View Post
If I was going to do a conversion to make myself a short course truck 4x4, you could look at the academy SBV2 as a platform. All you would need to machine really would be a chassis, upper deck, and longer drive shaft. the parts from the RT4GP truck can bolt on to the vehicle, and the 12mm hex is used front and rear.
Would probably make a decent light-weight conversion. For maximum durability (at the expense of weight), pretty much any 8th scale buggy makes a good platform too.
