Slowkrawl
High-Voltage Fetish
Slowkrawl's Avatar
10.11.2009, 07:27 PM
Novak makes great products but it would be a turn in the opposite direction, The Flux is basically a Steve NEU designed Castle 2200kv motor with a different can/heat sink.
If your running 2s in series, a upgrade would be a Genuine NEU motor 1515 Y. I would suggest you spend you hard earned money on drive train upgrades and worry about another motor when you roast the one you have now.
I run it on 6s, and you may have a valid point. I more or less just wanted to know what my options were, for future reference. I have the diffs set up to where they seem to be holding, and just installed the HD drive gear. I'd still like a little more speed, maybe because I'm an idiot?
