alport
10.17.2009, 06:46 PM
Ok. I tried something that you said. I'm hundred percent sure my radio working correct and I measured the voltage on the receiver wire 5.82V so the the bec is OK too. After trying differnt solutions my problem changed a little. İf I first open the esc (not calibrating) it launchs with its classical ringing and blinking three leds and then only the red led begin to blink and the motor don't works on throttle or brake.This means that the esc need to be calibrated. If I try to calibrate the esc and launch it on full throttle it opens again with its classical ringing and blinking three leds and then there is only solid yellow. After the solid yellow led if I let the trigger to neutral position the motor moves forward.
I'm sure my radio is working properly and my throttle subtrim is at neutral. I need your help!
