Regardless, your setup will be spinning it close to 40,000 RPM. Depending on how you look at it, the sweet spot could be 30,000 RPM or 45,000 RPM. Some say 30K because it would run the coolest, but the sweet spot could also be 45K because you have 50% more power available and maybe only 30% more heat.
