10.18.2009, 10:57 AM
The CR Buggy(Jammin') mount has the same hole pattern on top and bottom, but the top uses m3 screws and the bottom uses m4 screws. I don't know if the bearing hole is centered top to bottom, but it is pretty close. Most of the mounts do allow the entire center diff assembly to be reversed by adding a spacer underneath for spur gear clearance(puts motor in left front opposite the steering servo and is common position for dual battery conversions).
The easiest way to determine compatibility is to match the center diff bulk part numbers - if another car uses the same part number and the ST-1, then the ST-1 motor mount would likely fit. :)
